well i get my pipes my silincers my new carbs and boost bottle off of ebay
i put some oil in the bottom end (because the head was off at the machine shop being shaved)
i put a new .025 over top end
in the meantime i put my new clutch in it my new water pump prop and other dodads
i get the head back put it all back together and for got about the oil in the bottom end kick it a few times it fires it hyro locks and bends a rod
so i pull it back apart ( lucky for me i work for a machine shop :clap: ) i had the cylinder crack tested and it turns out
the rod bent cracked the new piston cracked the sleve and cracked the casting of the cylinder!!!
so now im back 2 stage one never again will i ever forget about the oil in the crank case :baseball_wibble:
short story but i figerd i would share
well i got a complet bottom end for $250 canadian
and i got 2 .050 over jugs for $50 canadian ( lucky me lol)
so im gonna make a quick motor just 2 use the poor bike LOL
but untilo i get the motor together im still gonna :baseball_wibble: like a girl
and i plan on makein a cub ( maby) if i can afford it over the winter ( chrome everything LOL)
:flamewar:
