i am about a wits end with it, i cant the that thing to seal off i gobbed silicone on it and it still leaked, so as a last resort i applyed a thing layer on the tank gasket and the valve housing and the gasket then put a seal around the out side of it... i think it was leaking where the screw holes are but im not sure.
also it was leaking where the valve and the housing meet the big screw hole so i put some silicone and locktight around it too and if this dont fix it then i dont know what the hell im going to do
anyone else have these problems
and if i tighten the screws up alot it squishes out the gasket too!
Edited by AustinONeal
well what i dont understand is you have to tighten it down and when u do it gasket squashes out well that just doenst work out right, cant tighten it down or it will leak DONT tighten it down and it will leak
worth a shot , also use that gasket maker shit very lightly. i mean it may be like a rig but hey if it works, it works....... i know if that problem was holdin me up i woulda tried everythin even welding LOL
i made a gasket out of a thin piece of rubber didnt use any sealer no leaks as of yet use teflon tape for the threads
did you use teflon tape on the threads of the fuel valve that screws into the mounting plate?
no i put a litle bit of silicone on the threads
you need to rap the threads about 6 or 7 times with the tape to index it to the position you want it. you will probly have to do that a couple of times to get it were you want it.
