banshee#1 Posted June 24, 2006 Report Posted June 24, 2006 Hey i have a banshee mods in sig im runing 33mm single and toomeys with a portjob. if i went with a drag pipe like GRR CPI RDZ Sheares Rockets which are the best on top end would i see a big increas on top and still have bottem end from the single carb or just get duals and a drag and +4 timing? i honetly like my single so ill get a 35mm then jet it right woudlt hat be okay and in the near future rebuild what are some good cranks or 4mm strokers lmk also how much will this increas on top of my setup now. (pipes or and carbs) then with a 4mm thanks alot Quote
sheefreak Posted June 24, 2006 Report Posted June 24, 2006 You would need to run a spacer plate since your cylinders are already ported for a stock stroke if you go w/a stroker. I would personally run a dual carb setup if you are looking for top end, but I have never run a single carb setup. I would call and ask Cam about your setup seeing that he ported it. He can tell you what will and won't work w/his porting. When you hire a builder for porting, get your moneys worth. He should have no problems w/you asking questions. He wants your bike to perform well too. After all it is his name on it. Two strokes are unbelievably finiky w/setup. You might make one or two minor changes as far as setup, and all of a sudden find 10, 15 horse. Quote
banshee#1 Posted June 24, 2006 Author Report Posted June 24, 2006 like carbs and pipes or a top end pipe? Quote
sheefreak Posted June 24, 2006 Report Posted June 24, 2006 like carbs and pipes or a top end pipe? Yes. Also timing, and compression. Especially on the pipes though. Depending on his portwork, he will tell you exactly what responds best to his port timings. I would bet he will tell you Shearers, but maybe not. Quote
