night Posted June 21, 2006 Report Posted June 21, 2006 Where is snorkel located? How do you remove it? What are its uses when on? What are its uses when removed? Quote
pipebomb Posted June 21, 2006 Report Posted June 21, 2006 (edited) Where is snorkel located? under the seat, attatched to the air box lid. How do you remove it? unscrew the little clamp that holds it to the air box lid and yank it off. What are its uses when on? an air intake for the airbox to draw air from a higher and more protected area to reduce the amount of incoming forgien materials( dirt, water, etc), restrict air flow to the airbox to limit horsepower output of the engine. What are its uses when removed? Trash, recycle, or put on eBay for $5. Edited June 21, 2006 by pipebomb Quote
night Posted June 21, 2006 Author Report Posted June 21, 2006 under the seat, attatched to the air box lid. unscrew the little clamp that holds it to the air box lid and yank it off. an air intake for the airbox to draw air from a higher and more protected area to reduce the amount of incoming forgien materials( dirt, water, etc), restrict air flow to the airbox to limit horsepower output of the engine. Trash, recycle, or put on eBay for $5. Thanks a lot my dear friend pipebomb, You Are Greatest of the Greatest. Quote
