hey i have toomy t-5's right now along with redline racing port job, cool head 20cc domes vforce3's trinity 2 in 1 carb
im look to gain more mid/ top but i do not wanna loose to much bottom end i sorta wanna stay the same in botom mayb sacrifice a little
which inframe would be best for me and will i gain alot ovr the toomy's
also a stator timing plate would i benefit low end . i dont plan on running race gas i run 93 octane would i be able to get by along with 20 cc domes or its cuting it close? would octane booster help if i didnt wanna run race gas?
CPIs have better bottom end...not as much top as Shearers...You're going to lose bottom period by going to a drag pipe...
First, what's your elevation?
Second, what is your compression at?
Honestly, if you're looking to gain mid/top...ditch that dual carb setup.
Putting on a top end pipe, then crippling it with a 2 into 1 carb setup is counterproductive...
Need to know your compression before anyone can tell you if bumping your timing will require race gas.
Honestly, octane booster is a major pain in the ass on a two stroke. You already have to mix X gallons per X oil...add octane booster in, and you're causing a headache, while only saving a minor amount of money.
If your numbers add up, you're better off running a mix of race and pump gas...
Edited by dajogejr
