racer714 Posted April 6, 2006 Report Share Posted April 6, 2006 Hello everyone, I havent been around much lately, way too busy with wedding and house remodeling shiz. Anyway I pulled the winter cover off the shee last nite and i noticed my twist hrottle doesnt snap back like it is supp to. No way I want to ride this beast like that. Any advice/ could it be the cable?? is it possible to lube the cable, I do my clutch, just never have done my throttle(twist). Could it be the slides? I havent kicked her over in about 4 months, I got a yfZ now too, so ive been using that for awhile. thanks!! Quote Link to comment Share on other sites More sharing options...
Wallrat Posted April 6, 2006 Report Share Posted April 6, 2006 Yeah just unscrew the 2 screws clamping the twisty together. Take it apart slow and you'll figure out all the pieces and their positions. I'd imagine a few squirts of tri-flow or some silicone lube on the tube and then some cable lube should do it. That said, never hurts to pull the carb caps off and see how gooey your slides are. Quote Link to comment Share on other sites More sharing options...
racer714 Posted April 6, 2006 Author Report Share Posted April 6, 2006 thanks wallrat, ive actually pulled it apart last pm and cleaned real good, just didnt lube the cable? do I have to remove the carb tops and remove the cable from the slides to lube the cable?? Quote Link to comment Share on other sites More sharing options...
LeadBoots Posted April 7, 2006 Report Share Posted April 7, 2006 how old is ur throttle cable maybe you need a new one Quote Link to comment Share on other sites More sharing options...
racer714 Posted April 7, 2006 Author Report Share Posted April 7, 2006 thanks wallrat, ive actually pulled it apart last pm and cleaned real good, just didnt lube the cable? do I have to remove the carb tops and remove the cable from the slides to lube the cable?? 498452[/snapback] come on guys any input on this?? thanks Quote Link to comment Share on other sites More sharing options...
racer714 Posted April 7, 2006 Author Report Share Posted April 7, 2006 bump! The cable worked fine last time I rode it in NOv Quote Link to comment Share on other sites More sharing options...
LeadBoots Posted April 8, 2006 Report Share Posted April 8, 2006 bump! The cable worked fine last time I rode it in NOv 498908[/snapback] my throttle cable was fine to the last time i used it but now it does not work. Quote Link to comment Share on other sites More sharing options...
Wallrat Posted April 8, 2006 Report Share Posted April 8, 2006 I never bother to pull my caps. Just lube the cable and see if that helps. Quote Link to comment Share on other sites More sharing options...
racer714 Posted April 11, 2006 Author Report Share Posted April 11, 2006 I never bother to pull my caps. Just lube the cable and see if that helps. 499052[/snapback] thanks wallrat! damn, I used to live in HB too, I miss it almost everyday! Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 11, 2006 Report Share Posted April 11, 2006 I'd take apart the throttle assembly, make sure the bar is clean and free of goo, and lube a bit, and...the cable as well... Quote Link to comment Share on other sites More sharing options...
