Recently put in a new top end with Vito's power up forged pistons 50 over bore. Banshee runs fine when fuel is added to carbs to get it started i.e. carb clean, but when you stop adding fuel it bogs out like it is starving for fuel. cleaned out carbs several times and cleaned out reeds. What next?
Take your fuel line off of input to carbs and see if fuel is flowing to that point. If it is, recheck you pilot jets, make sure they are as clean as possible. If you are getting fuel to the bowls, and pilot jets are clean, there is no reason you shouldn't be getting fuel to the cylinders.
