Drakaar Posted March 9, 2006 Report Posted March 9, 2006 Heya everyone, since installing my tors removal kit, I'm having a problem with my low beam headlights. I got the Vito's tors removal kit and installed it as per the dirrections and the posts on this site, but after I got it all back together, my low beam headlights and the taillight will not work. They both work fine on high beams, it's just the low beam circut that seems to be out. I am just wondering if anyone else has come accross this problem, or if anyone has some sugjestions on what or where I may have screwed up. I unplugged the tors box, the throttle switch, the e-brake switch, and the carb tops, and the bike runs fine, got the carbs drilled and tapped so it idles nicely but like I said, no low beams............ Any help or insight on this problem would be greatly appreciated, thanks in advance..... Btw, it is a 2003 shee Quote
pipebomb Posted March 17, 2006 Report Posted March 17, 2006 I'd double check all your wire connections. could have pulled one of the connectors or a wire loose and just far enough apart that it's not quite making contact. I've has a brand new replacement wire harness have a couple of bad connections in it where the wire wasen't pushed all the way in to the connecter. Quote
