GOT A DUNE BANSHEE 4-MILL WANT TO TRADE FOR A BIGGER MOTOR AND A LITTLE MONEY. OR TRADE STRAIGHT UP IF MOTOR IS NICE ENOUGH.
MOTOR: 4-MILL, DRAG PORTED BY JHC, OVERRIDE TRANNY 1-5, ALL NEW BILLET SIDECOVERS, BARNETT DIRT DIGGER CLUTCH, CPI PIPES, 34MM MIKUNI CARBS, PRO DESIGN COOL HEAD, PAINTED SILVER CASES AND CYLINDERS, GOT ABOUT 30 MINUTES SINCE REBUILT.
COLOR:HOUSE OF COLOR, HOTTER THAN PINK.
FRAME:MODIFIED STOCK FRAME, +7 SWINGARM, CHROME A-ARMS SPINDLES STEERING STEM, BILLET REZZY, BILLET GRIPS, POLISHED THROTTLE, BILLET HANDLE BAR CLAMP, POLISHED CLUTCH LEVER, STEEL BRAIDED BRAKE LINE, COMES WITH STOCK WHITE SHOCKS, ALSO COMES WITH 12 PADDLES.
MUCH MORE IM MISSING.
what size bore is it and is there any pics , i might just take it off your hands if u can gurantee its a drop n go motor . and is there any pics of the port work does it have shaved heads whats the approx compression.
if your not just messin around and you actually want it i will pull intakes and show you pics of porting. by the way precision powersports call them and ask for joe he built the motor and will tell you what it is just be sure you tell him its kyle bates motor.
Edited by sandbanshee32
