Ok I just bought a new clutch kit and installed it. Followed all instructions and put it back together the way it was and got the arrows lined up. When i put it in gear with the clutch lever pulled it wants to jump and go. Anyone know what the problem is? I have a new clutch basket also.
Mine will do it once in a while, but if I put a jack stand under it, so that the rear wheels are off the ground, it's running, in gear with the clutch pulled in, the rear wheels will spin, although slowly. Did you soak your clutch plates in oil, before installing them? You will also have to break in the clutch, before it performs 100%, like it should. It's kinda like putting new brake pads on, everything needs to "wear in", to work right.
