Parting the 97 banshee out. Everything is in mint condtion exept the motor, the chain snapped and took part of the top part of the case off but it DOES NOT leak oil.
Whatever you guys need let me know, i have everything exept pipes and chain.
I have some parts that are brand new like-
1. Black UFO plastics, brand new- $275
2. AC racing nerf bars with black netting, brand new- $100
3. vitos +4 degree key, brand new- $15
4. FMF silencers, used one ride- $130
5. Protaper atv low bars- $50
6. Ac racing grab bar- $60
7. Powermadd handguards (red) with mounting kit- $60
8. UPP chain rollers, and chain slides(red)-$ 80
AFTERMARKET PARTS-
1. DynaFS ignison- $200
2. DG front bumper- $40
3. Mukuni 28mm flatside carbs- $150
Make offers on any stock parts that you need, i have everything exept chain and pipes. -MIKE
i need the top part of the kicker..let me know what you've got asap (60411)
435111[/snapback]
I have a person that might want the motor, so it depends on if he wants the kicker with it or not, but if he doesent ill let you know.
i need upper a arm bolts, rear brake calliper, and a swinger if its in good shape.. good bushings and all.... and how about a rear shock... and front shocks.. please give me seperate prices
435126[/snapback]
The break calliper is in good shape and the swing arm is in good shape, i had it sandblasted by a buddy of mine then i primed it and painted it black, i never used it sence then. The front shocks are bent a little but the rear shock is fine. If you get something from me ill just give you the a-arms bolts.
1. break calliper- $75
2. Swing arm- $50
3. rear shock- $40
4. front shocks-$30
