logan#1 Posted November 5, 2005 Report Posted November 5, 2005 I am getting t-5's this weekend and should i get a jet kit and intake with it or can I wait. Quote
Too Many Toys Posted November 5, 2005 Report Posted November 5, 2005 I am getting t-5's this weekend and should i get a jet kit and intake with it or can I wait. 433328[/snapback] If your banshee had stock pipes before then you will definitely have to re-jett and will want to at least get some bigger jets. You could wait on the intake if you want. Quote
2003LimitedBanshee Posted November 5, 2005 Report Posted November 5, 2005 Toomey will supply you with a "Perfect Jet Kit" that will suffice if you are running the stock airbox. It comes with 270's (above 2500') and 280's (sea level to 2500'). If you don't ride in the mud, real wet etc. you could also do the high flow 2:1 UNI filter setup. However, if you do this you will need to get some bigger jets than the 280's that are supplied, as it will now flow more air than the stock setup. If you go with the 2:1, you should look into jets around 300-330, depending on elevation, temp, and additional mods. Quote
