The problem that I am having is that, after warm-up, it runs very "rich". When it's idoling, I can turn the fuel off and, after about 10 seconds, the RPM's increase to about 2000 RPM until it runs out of fuel. Does anybody have any ideas about this?
Thanks :blink:
This sounds as though it might be a float height, or stuck float needle issue. If the float is set to high it could be causing the rich problem, but as soon as you turn the fuel off the bowl is not getting replenished, thus it leans out to the proper (idle rpm would be a bit high at 2000) idle speed. I would start by checking that out and try flushing the carb. I have cleared out stuck floats by removing the carb, and spraying aersolized carb cleaner into the fuel inlet line on the carb.
