Supposedly, if the nasty tors demon strikes, it will be when you are WOT just about to attempt to jump a 60' gap. tors is supposed to cut spark when when it senses your throttle is closed but the slides or slide is stuck open. Maybe you have a sticky slide? Might just give the carbs a good solvent bath to get off any gooooey oil buildup on the slides and the problem may go away. But get rid of the tors aventually.
I have the elim kit in my garage but I was so anxious to ride I didnt put it on. So it will kill the sheee then?
419900[/snapback]
I never had the problem at full throttle.
At idle the thing was a nightmare, you couldnt hardly keep it idling. So I took out the little sensor that goes into your thumb throttle with the little nipple on it, and hasnt died at idle once since.
