I bent my stocker so now i need a new one and i was thinkin about gettin a G-Force Axle. How well do these compare to a Durablue or something? And another question.. Will i be able to use all my stuff off of my stock axle?? Like my brake hub, sprocket hub, stock carrier. Thanks for the help. MEADOWS. :dance:
the samw happened to me, yes all your parts will fit, the reason I went with a g-force is because it has a true lifetime warrenty, I was going to buy a durablue and actually was on the phone with rockymountainatv.com when I had a change of heart, the guy on the other end said durablue had made some changes to their policy, he said you could bend,break a durablue axle and the first exchange was free, thereafter they charge you 175.00 per break or bend, g-force says in their policy they will exchage as many times as necessary and you get out about 80.00 bucks cheper. I love my g-force, I jump alot and high also never had a prob. I would highly recommend g-force instead of BENDABLUE. :cheers:
Yes the g-force axle is a cheap alternative to the other axles on the market. You can use your stock brake and sprocket hubs and the three piece locknut comes with it. Nothing to worry about, 10 minutes of installation and your back in business, screaming the rubber off your tires.
