2004LEBanshee Posted August 23, 2005 Report Posted August 23, 2005 I have a couple questions about installation. The kit came with a short line that has a T shaped box on it and 2 equal lenght lines that I assume connect to each brake caliper. But where does the short line with the "T" block go. Does it connect to the break resivor and the hard brake lines or what. Oh and how do you guy get the lines that go along the a-arms to stay there. With the aftermarket arms there is no line holders so do you just zip tie them ? Quote
DUNEDEMON Posted August 23, 2005 Report Posted August 23, 2005 The short line out of the "T" should connect to your master cylinder, the remaining 2 lines connect to each caliper, your new lines should replace all factory hard lines, soft lines and junction block. You'll have to use zip ties or billet clamps to secure the new lines in place, and a Mity Vac hand held vacuum pump will make bleeding the brakes a snap. Good luck.... Quote
2004LEBanshee Posted August 24, 2005 Author Report Posted August 24, 2005 Thanks alot I figured that out when I saw how long the lines were. Thanks jason Quote
