99 Shee Owned three months Compression check good,New LSR +2 axel,Pro Design water impellar,T-5's,K&N filter,Jetted,RK chain,UPP guides, I have good mech skills, but have not had any experience tearing into the guts of a SHEE!
I am a machinery repair tech. on CNC equip. at a company that makes heavy off road equip. and mining equip. for Cat and Allison Trans. not bragging but I do know a little bit about each mech,elect,hyd,pne so I know which end is the open end of a combo wrench haha. would kinda like to know some of the mods that can greatly increase durabulity of the engine. Working on trying to build up not blow up!!!!!!!!!!!!!!!!
THNKS,
D.D.
:headbang:
Maybe if you post a pic of the part you found we can identify it and go from there. The tranny is pretty simple to split because the halves lift off one another, and then all the gears and stuff will stay in the bottom half.
My 1st guess would be the shift shaft centering pin, does it have a slot for a straight blade screwdriver in one end of it?
I had that happen to me earlier this year, the piece looked like it was 3/4" in length and maybe 1/4" diameter. I was told it was part of the shifting mechanism that had worn down slightly and fell out of it seat. A new one was ordered and replaced . The location is under the clutch cover.
Grounded you are right on the money.that is what I think it is.
I was out working on it last night and this mourning.
Is ther something that can be done to this assy ?
Like I said I would like to build up not blow up!!!!
THNKS,
D.D.
:headbang:
