hey im still fighting this jetting thing...i got fmf gold series fatties powercore2 sil. k&n filter no lid, 260 mains came with the pipes i trid them it wasnt right...so i got 27.5 pilets and 280 mains well still not right so back to the shop and get 310 still not right,, i have no bottom at all,,,and it sucks gas like crazy about 3 hours on a tank....can anyone help me out? im about sea level
398290[/snapback]
Elmer- your main jet does not effect your bottem end (banshee's dont have much in the first place). First off, when your tuning your carbs start out with a clean airfilter. Try a 320 mains and if it craps out at WOT (if not try 330's) put the 310's back in with the stock pilots. Then dial in your airscrews and you will be set!
ok thanks man,,,by no low i mean just idle'n along at a high idle in 2nd gear and hit it it spits a couple times then bogs.....but y would it be usibg so much gas?
398385[/snapback]
When you put in bigger jets, more gas is going to flow threw them. Can you give us some detail on where it is sputtering (before powerband, at the first part of the powerband) ? Where is it boging? 1/2-3/4? 3/4-WOT?
