FOXBANSHEE30 Posted July 1, 2005 Report Posted July 1, 2005 i have a major problem that i cant figure out. My banshee wont idle, it loads up on the bottom end, runs good 2nd through 3rd, in 4th it will run right unless i open it wide open and it seems to almost quit but if i let off and just gradually accelerate it runs good, but if i good wide open is falls off with no revving and no power. I have changed the main and the pilot jets and still cant find the problem. i have fiddled wih the idle screw and the air screw and cant get it right. The only thing i havent messid with is the needle. I have a Trinity Stage II 2 into 1 carb kit w/ a keihn PWK (not sure what size). Can anyone help me?? I need it bad. Quote
sredish Posted July 2, 2005 Report Posted July 2, 2005 Have you ran any plug checks? If it's running bad at full and you just back off to 3/4 and it picks back up, pretty obvious which jetting circuit.... Read THIS for more help on the troubleshooting and let us know if you have questions. Quote
FOXBANSHEE30 Posted July 2, 2005 Author Report Posted July 2, 2005 gigidy-gigidy all right!! I found the freakin problem!! My needle was broken thats why i couldnt dial it in. So now i need a new needle. Do i need a specific size?? Or taper or anything?? Thanks in advance for the help. Quote
wesw Posted July 3, 2005 Report Posted July 3, 2005 wow how the fuck di dyou break a needle but anyways you can call sudco.com and tell them the letters and number on your needle and they will hook you up. Quote
FOXBANSHEE30 Posted July 4, 2005 Author Report Posted July 4, 2005 i broke a the needle cuz im just that bada$$! no im jokin i have no idea how i broke it. Well the needle doesent have any numbers or letters on it. So what do i do now? I could use the help. Thanks. MEADOWS. Quote
wesw Posted July 4, 2005 Report Posted July 4, 2005 there should be some number or letter on teh top of the needle if not call sudco and tell them what carbs you have and what they suggest. would be your best option Quote
