NOSJunkie Posted June 26, 2005 Report Posted June 26, 2005 I have a lathe. And I would like to lighten my flywheel. Obvisiouly you dont want to cut the pickups off. How much do you cut? how deep? and how close to the pickups?.. Thanks.. Joe Quote
98bonerSTOCKshee Posted June 26, 2005 Report Posted June 26, 2005 PM Boonman or BdBanshee. I'm sure they can both take care of you. or do a search...I did it for you.. Quote
NOSJunkie Posted June 26, 2005 Author Report Posted June 26, 2005 They both make a living off that kind of work so it does not feel right to ask them for there info. If they want respond to this post that will be great. I'd like to know exact demensions of the cuts to make.. Quote
Stinger Posted June 26, 2005 Report Posted June 26, 2005 Around the outside, take off about the same amount as the pickup is thick. On the face, just take off enough to make it look nice (the weight is around the outside, not on the face). You can also slot the holes if you like... I took a little over a pound of material off of mine. Quote
NOSJunkie Posted June 27, 2005 Author Report Posted June 27, 2005 You cut more than 16 ounces? I have heard of people cutting 8-10 ounces, but not 16+. Have you had any problems with it? Quote
