hey guys i was wondering is 17cc domes too much compression with a stock crank and am i losing top end rev having those on....I have some 19cc domes that i could throw on. Also if i port my motor would the trinity single carb set-up work
17cc domes will be too much if you are around sea level. If you are 3000 ft or above, you can probably get away w/it. At sea level you will be lookong at around 200 psi, which means you definately have to run race fuel also. Porting will bring your compression down some, but I can't tell you to what, also depends on the porting, your builder should be able to help you w/that. Not too sure on the 2 into 1 setup.
