THEREALBUDLIGHTBANSHEE Posted May 3, 2005 Report Posted May 3, 2005 on a steep hill in the sand you stop or get stuck after a few minutes the clutch goes away,soosn as i get back on level ground it's fine anybody ever had this problem Quote
Wallrat Posted May 3, 2005 Report Posted May 3, 2005 Sounds like your clutch is either out of adjustment or the plates are worn. Either way your going to notice it first on inclines or when getting on the gas hard. Eventually if left this way it'll start doing it on the flats too. Check that you don't have alot of play in the clutch lever, then check down on the engine case where the cable pulls on the clutch arm. The clutch arm has a little arrow that should match up to another little arrow on the engine case when you put some pressure on it with your finger. Quote
