Tissan Posted April 12, 2005 Report Posted April 12, 2005 does anyone know the stock width of the swing arm at the pivot bolt? I tried searching but came up with nothing, thanks. Quote
Tissan Posted April 12, 2005 Author Report Posted April 12, 2005 Also, i've never removed a swinger. Done about everything else, but never a swinger. Can i remove it with the tires/axle still on? And is there any bearings i have to replace when i remove it? Quote
chapmanmd Posted April 12, 2005 Report Posted April 12, 2005 Also, i've never removed a swinger. Done about everything else, but never a swinger. Can i remove it with the tires/axle still on? And is there any bearings i have to replace when i remove it? 354168[/snapback] The width at the pivot is 8 and 7/8 inches You can remove the swinger with the axles and tires and stuff still in it, but why??? You will need to remove the big pivot bolt, the dogbone bolt that bolts to the frame, brake caliper, shock. If you are going to the trouble of removing the swinger, its probably a good time to take a look at your pivot bearings and tube. If theyre loose or gritty looking, replace them. Good Luck... Quote
Tissan Posted April 12, 2005 Author Report Posted April 12, 2005 Thanks man, i was thinking would it be a better(and easier) idea to just take the axle carrier off the swing arm? then remove the swinger? Quote
chapmanmd Posted April 12, 2005 Report Posted April 12, 2005 Thanks man, i was thinking would it be a better(and easier) idea to just take the axle carrier off the swing arm? then remove the swinger? 354206[/snapback] That would work too. Why are you taking off your swinger? Quote
Tissan Posted April 12, 2005 Author Report Posted April 12, 2005 That would work too. Why are you taking off your swinger? 354207[/snapback] Well i have a swingarm off of a 88 Ninja 600, its the same width as mentioned above so i want to see what modifacations it would take to convert it into a 3 wheel setup and make it street legal registered as a trike. Before i do anything else to legalize it i figure i'll see if i can get this swinger to fit Quote
Tissan Posted April 13, 2005 Author Report Posted April 13, 2005 Good news guys the ninja swinger fit perfect. Shock mounts need some fabbing done, but thats a given. I'll get some pics up soon Quote
fixitrod Posted April 13, 2005 Report Posted April 13, 2005 (edited) Holy Cow........ Can you cut the back of the ninja swinger and attach it to the banshee swinger. Then you wouldn't have to fab the mount. Edited April 13, 2005 by fixitrod Quote
Tissan Posted April 13, 2005 Author Report Posted April 13, 2005 Holy Cow........ Can you cut the back of the ninja swinger and attach it to the banshee swinger. Then you wouldn't have to fab the mount. 354352[/snapback] i could, but i want to be able to switch from 4 wheels to 3. All i have to do is take some 3/8th inch flat steel and make 2 3 inch extenders since the shock on the ninja was longer. We'll see tomorrow, i have alot of work to do Quote
fixitrod Posted April 13, 2005 Report Posted April 13, 2005 somebody here can get you a stock swinger for cheap. Now the ninja swingarm may be hard to come by. Def let us see pics of this one. Were are you located. Quote
