How can you tell if you have a bad spark plug cap? Had my bike on the dyno and had an electrical prob at very high Rpm's. I checked wiring connections and plugs and they were good. I changed the coil and that helped, but I reused the plug caps. Can they go bad like that? THey are tight on the plugs. Any thoughts?
The resistors in the stock caps can fail. You can measure the resistance in the cap.
339967[/snapback]
Do you know what the resistance should be?.....I'm headin to Little Sahara Sat. ought to just pick up some new caps.
