endofitall9 Posted March 9, 2005 Report Posted March 9, 2005 Ok yesterday it would run but it didnt have all the power so I started messin with it abit checking to see if I had spark and what not. Then I took off my stator cover and out poored milky water and soon as the bolt were loose i tried starting it with the stator cover off and now it wont run, it will hit but it will not start. In the last 3 days I have went throgh all my electrical,cleaned carbs,checked for spark, and then then the stor cover now it will not run at all, any suggestions would be nice, and are 250r's this much trouble? Quote
~~Banshee~~ Posted March 9, 2005 Report Posted March 9, 2005 Ok yesterday it would run but it didnt have all the power so I started messin with it abit checking to see if I had spark and what not. Then I took off my stator cover and out poored milky water and soon as the bolt were loose i tried starting it with the stator cover off and now it wont run, it will hit but it will not start. In the last 3 days I have went throgh all my electrical,cleaned carbs,checked for spark, and then then the stor cover now it will not run at all, any suggestions would be nice, and are 250r's this much trouble? 336311[/snapback] Milky water sounds like coolant and oil.... Quote
ledofthezep Posted March 9, 2005 Report Posted March 9, 2005 Let the stator dry up, put the cover back on & try it. If it works, seal that bitch up good to keep moisture out in the future. What's the stator look like? Checked it with an OHM meter? Quote
