Minkia38 Posted January 23, 2005 Report Posted January 23, 2005 heres a pic of someones (thanks!) http://www.imagestation.com/picture/sraid1...7a/f99693f2.jpg but it stil ldoesnt help me - i thought that you were supposed to get rid of that spring on the arm.... need pics! Quote
SICK BOY Posted January 23, 2005 Report Posted January 23, 2005 (edited) I can't get your pic to work.I have had 2 Magura clucth kits with no problems.You leave the arm spring ON,and everything will mount right up.The only thing you may have to do is slightly bend the wire that bolts to the top case to keep the cable in place (I think mine was bent to start with ,that's why I had to bend it).Email me a pic of what you have,and I'll see what's going on.My email is [email protected] Edited January 23, 2005 by SICK BOY Quote
Banshee17Racing Posted January 23, 2005 Report Posted January 23, 2005 Ray, I sent you some pictures that I just ran out to the garage and took. Let me know if you need pics of something else. Just be careful not to bend the rod that comes out of the slave cylinder when installing everything. Did you get the plastic lines or the stainless steel? Quote
H250RHATER Posted January 23, 2005 Report Posted January 23, 2005 i dont understand why ur ahving a problem myn went together in under 5 min w/ no problems what problems are u having Quote
Minkia38 Posted January 24, 2005 Author Report Posted January 24, 2005 guess you alot smarter than me Hater It took me 5 minutes to take my carbs off I got it figgured out it didnt seem like it was engaging all the way, so I had to add a few washers. the instruction said to take the spring off, but Ive seen banshees both ways... Quote
SICK BOY Posted January 24, 2005 Report Posted January 24, 2005 guess you alot smarter than me Hater It took me 5 minutes to take my carbs off I got it figgured out it didnt seem like it was engaging all the way, so I had to add a few washers. the instruction said to take the spring off, but Ive seen banshees both ways... 310998[/snapback] Quote
