tinyman Posted December 26, 2004 Report Posted December 26, 2004 hi guys while riding my banshee yesterday i changed down a gear and the shifter went all sloppy,it will still change but the lever wont go to the central position?.so today i just pulled the side cover off and a little piece of steel plate with a hole in the centre and one side is all burred up fell out,any idea how to fix this,also how do you remove stator(i think thats what it is)and flywheel so i can see in there further any help will great regards tiny Quote
tinyman Posted December 26, 2004 Author Report Posted December 26, 2004 hi guyswhile riding my banshee yesterday i changed down a gear and the shifter went all sloppy,it will still change but the lever wont go to the central position?.so today i just pulled the side cover off and a little piece of steel plate with a hole in the centre and one side is all burred up fell out,any idea how to fix this,also how do you remove stator(i think thats what it is)and flywheel so i can see in there further any help will great regards tiny 297990[/snapback] i also checked the shifter star and it seems fine thanks tiny Quote
SICK BOY Posted December 26, 2004 Report Posted December 26, 2004 Do you have a pic you can post,so I can better understand what your looking at? Quote
tinyman Posted December 26, 2004 Author Report Posted December 26, 2004 hi sorry i havent got a camera at the moment,the piece of steel is approx 2cm square with one side of it is burred like it has been wearing on some thing,also is anything special required to remove the stator so i can see in there further thanks tiny Quote
JKJK Posted December 26, 2004 Report Posted December 26, 2004 which side did the unknown piece come out of?stator or clutch.to pull the flywheel you'll need the correct flywheel puller.it sounds to me like the problem is on the other side with the shift star assembly area.do you have a clymers manual to refrence?also look+see if their is still a c clip on the tranny shaft that holds the idler gear on.the idler gear won't come off whithout removing the clutch housing assembly,but i could bind up if the c clip is gone. Quote
BdBanshee Posted December 26, 2004 Report Posted December 26, 2004 Usually this is caused by the shift shaft centering screw breaking off. It is located behind the right side clutch cover. Here is a pic from the manual, #3 is the centering screw. Quote
tinyman Posted December 26, 2004 Author Report Posted December 26, 2004 thanks for te replys guys,ill have a nother look today and get back to you how i get on. thanks tiny Quote
tinyman Posted December 27, 2004 Author Report Posted December 27, 2004 hi ruys well the banshee is fixed ,there was a bolt broken thats holds the gear lever in the centre via a spring,i made another one up and away we go.this forum just saved me $$$. thanks tiny Quote
