Shee's bog'n down
Planin to go ridin for 3-4 days with some mates in 2 days time and hav'n problem gettin shee to run right...Problem is when i start it up and hold it at a constant RPM it bogs down and backfires and will die out if u dont keep rapin it on to get the revs back up...It will do this hot or cold and it is also has a problem hitting powerband at WOT...
I have removed and cleaned Tank,fuel cock,fuel lines,A/filter and both carbs...
Have replaced the plugs also
Any help would be appreciated
What size jets are you running?  Mains, pilots, and where is the clip on your needle at?
Definately sounds like a jetting issue.
297218[/snapback]
Not sure of sizes but ive been ridin this thing with no probs for a year now and all of a sudden from one ride to the next it started this
What about the TORS...Maybe i need to disconnect???
