I got a stock o1 shee i put fmf fattys with power 2 silincers and im at sea level about 75 degrees everything is stock airfilter and evrything .. is it going to do anything to it ? is it bad for the engine i ride woods and water im not goint to do anything to the box is that ok?
You can leave the airbox totally stock if you want although the snorkel doesn't do all that much more to keep stuff out of the air box than just the lid by itself and the snorkel holds back a lot of power. The stock filter sucks like mentioned already. If your doing this just to avoid re-jetting don't, if you run it really lean like you would be doing it will melt your pistons in a pretty short amount of time.
Ducman has a very good point, stock filter sucks and holds you some needed power. Also do not .... I repeat: DO NOT leave your jetting stock. The only reason to leave your jetting stock is that you may want to melt the pistons on purpouse.
Maybe I'm just a little :shootself: . Really, probably you would not burn a piston if you just restrict air flow, but then you will not gain a lot of power and the shee will not run as you wanted it to.
At least put 260 mains and take the snorkle off. If you leave the pilot (slow jet) stock size maybe you will not have problems during the somer but in the winter starting your shee could be a pain in the ass.
GOOD LUCK :cheers:
Edited by richybanshee
