My kids never seem to want to ride and I'm tired of seeing the bikes sitting on the trailer unused so here is a good Christmas present for somebody.
It is a TRX125 with an ATC110 engine. It fires up on the second or third pull when cold and first after it is warmed up. It has hi and low range with 4 speeds in each range. It can go from crawling up about anything to flying across the flats depending on what gear and range you are in. The front tires are pretty worn and the back are pretty new. This thing is solid and can get just about anywhere on dirt and doesn't do to bad in the sand either. We usually put it in low and throw some paddles on it and it will chug it's way about 3/4 up the first bowl at Sand Lake.
$800 OBO
