this is what i have done:
99 RED BANSHEE
MILLED
PORTED AND POLISHED
BORED .20
PAUL TURNER PIPES WITH FMF SILENCERS
HOT ROD CRANK
BOOST BOTTLE
v force reeds
150psi
+4 timing
lightened flywheel
is it beneficial to get my carbs bored. does anyone have a set to trade? how much jetting changes am i in for? is it worth it? is it a noticiable difference?
If you ride in any kind of water sell the stockers and buy some aftermarket. Jetting is a lot easier with aftermarket carbs also. I think with porting you will notice a difference with 28mm but you will have to redo all the jetting.
Stock carbs stick when they get wet. If they don't now, they will. Stock carbs are tough to jet to. If you haven't gotten a tors removal kit and want bigger carbs, just buy some.
$50 for kit
$80 for bore
That's $130
Now
$200 for new carbs and cable
then sell your carb's for $40
You're only paying $30 dollars for better carbs.
Just the way I see it.
thanks for the infro . i woudlnt have all that done to my quad and still run the tors. only a goof ball would do that. :jesterlaugh:
I have a set of bored stock carbs for sale if your interestood. I would think the jetting wouldn't change very much if any, maybe 1 or 2 sizes larger on the main and 1 clip position on the needle at most.
