hi
i wanted to change my clutch in my shee so i was wondering if changing the flywheel would make any difference i want some opinions from ppl who tried them on there banshees ??...and about the clutches iv heard that changing with a heavy duty clutches is not that good or a good option and i should only change the springs is that true ??
not to sure about the clutch, but getting a new flywheel w/ stronger magnets and a 200 watt stator will increase the power of your lights in the lower rpm's. u can also get the flywheel lightened which makes your banshee rev faster and expands the life of the crank.
You should do a search, we have debated this subject many times. There are many testimonials from people that have had it done and loved it, and the usual it doesn't work from those that haven't tried it.
