I just bought a Trinity 2 into 1 with a 34mm PJ. My question is should I start looking for a 35 mm PWK? I didn't really want the 33mm because I eventually plan on ported and have no problem with the supposed harder jetting. I heard the PWK's flow MUCH more air and have all around better performance than the PJ. And when a carb is set-up by SUDCO, what does that exactly mean? Would I have to find a carb that is set-up by them or just a 35 mm PWK? Any input is appreciated.....I'm a little lost.
Josh
Sudco is actually the company that imports them, so don't worry about that. Also, I'd run your PJ, there is nothing wrong with it and it should give you the power your looking for. As far as, how much more air a PWK flows, I don't really know, I haven't seen any test results or heard much, it might flow a little more air, but I don't think it will really be noticeable unless your running a big stroker or something.
I'd definitely run the PJ and have fun with it, it'll probably suit you very well.
