DMAN94 Posted August 9, 2004 Report Posted August 9, 2004 upgraded to dual ss lines. anyone ever have a problem with the bolt goin into the res? i tested each line and had perfect pressure with the stock bolt in with only 1 line. when i put the dual set up bolt in, it will not make the seal. all parts where new. i had so much pressure on the bolt i thought my res. threads where going to give out. i'm waiting to here from the manufacturer today. i was just seeing if anyone else has had this problem. any advice. thanks dennis Quote
Cotton eyed Joe Posted August 9, 2004 Report Posted August 9, 2004 upgraded to dual ss lines. anyone ever have a problem with the bolt goin into the res? i tested each line and had perfect pressure with the stock bolt in with only 1 line. when i put the dual set up bolt in, it will not make the seal. all parts where new. i had so much pressure on the bolt i thought my res. threads where going to give out. i'm waiting to here from the manufacturer today. i was just seeing if anyone else has had this problem. any advice. thanks dennis YES!!! The only set I've ever put together went on my bike, and I'll never do it again that way. Now I can get the parts I need to fabricate single lines out, then T to each from brake. I Finally got it, but it was the biggest bitch ever. That was also my exact problem. Getting the seal needed to maintain pressure. Quote
