I have had my shee a year and recently got new V force reeds. In the process of installation i noticed the the wireing runs over the crossover tube and down the engine. whell I was moving the wireing asside and noticed that the tube was getting a grove warn in it. Also some wires had the coating worn off and some wire fibers were cut. In a few months I probably would have cut some of them completely. THat would have been bad and I probably would have never figured it out. So I wrapped them in tons of electrical tape and secured them so that they cant move. Just thought some of you might wanna check it out. ;)
  • 2 weeks later...
yea you should loom the wires there and while you at it you sould un hook the tors brain and get thouse stock rubber spacers out your clutchs and get some stiffer springs or shim them and you have a longer lasting clutch if you mod u banshee i rec a mild mod like tors remove kit pipes and k&n power kit this is good set up for every day rideing :yank:
