Motoman991 Posted August 3, 2004 Report Posted August 3, 2004 I have replaced my my clutch plates and stuff but i have a question, on the bolt that pushes the clutch plates out is there suppose to be a ball bearing type thing in it, cuz i have one that i have no idea where it came from, any help is appreciated Quote
ybanshee203 Posted August 3, 2004 Report Posted August 3, 2004 (edited) Do you have a Clymers repair manual? If not you need to invest in one, they are pretty handy sometimes. There is a "ball" that is behind the pressure plate. It is located in front of the pushrod that engages/dis-engages your clutch. Take the pressure plate and clutch plate assembly off, then if you don't want to mess with taking the clutch nut off get a flash light and look behind the clutch nut(directly in the center of the nut)and this is where the "ball should be. If there isn't one you will have to remove the clutch nut and push the ball back against the pushrod. Then just re-install everything and adjust the clutch BEFORE installing the clutch cover. Hope this helps. Edited August 3, 2004 by ybanshee203 Quote
