limitied03 Posted July 8, 2004 Report Posted July 8, 2004 alright i jus rebuilt the shee and it was my first time and i got all the motor stuff right and when i went back hooking up the cooling system i know i got all the hoses right except for the overflow hose....like the one coming out the top of the radiator on the left side it goes into the bottle? but top or bottom and then you have the little hose that comes out of the water pump and T's into another small hose and i know one side goes up by the handlbars and is just an overflow but where does the other side go? i know my explanation isnt that great but any help will be appreciated... Quote
Holyman Posted July 8, 2004 Report Posted July 8, 2004 OK the hose that goes from the radiator to the coolant bottle goes intot the BOTTOM fitting on the bottle. The hose that comes out of the top of the bottle is supposed to go by your right pipe so it will steam if you boil over. I would {and have} moved the bottle to the front by the bumper so it's out of the way and won't spit coolant onto the pipes. The other hose that comes out by the water pump hooks to a T that is connected to the other hose that comes out right next to the rear engine mount and then that runs up behind the tank. These vent the crank case. Quote
ledofthezep Posted July 8, 2004 Report Posted July 8, 2004 Looks like Holyman's got ya straitened out, I re-routed my hoses so they all go south between the back of the frame & the swingarm. Quote
limitied03 Posted July 8, 2004 Author Report Posted July 8, 2004 Thanks alot guys....i think i got everything straight now...i knew this place would come in handy one day! lol Quote
