Get the carbs drilled and tapped for the idle kit. Then, put the carb tops on the new cable. Put the cable(s) into the slide(s). "thread" the spring onto the cable. Insert the slide into the carb, with the cutaway facing the air cleaner. Hook up the throttle, disconnect the TORS brain under the left side of the tank, and fire it up. Set the idle, and go ride. (oh yea, don't forget to file alot of material fro mthe side of the carb where the idle screw goes.). You don't happen to know what size tap it is? It should be marked on the tap. If you could tell me what it is, that would be great!!!
The tap size is M6 * 0.75. So I put the slides on first without the spring then just thread the spring around the cable. I am just having a problem getting the two cables to stay in the little plastic peice that connects them to the upper portion of the cable that goes to the assembly.
You can put the other end of the cable in the throttle housing, and hook it to the throttle. THis will keep some tension on the cable.... And it won't let the cable pull out.......EDIT::: And thanks for the tap size!!!
Edited by boonman
hey i got it man it was alot easier to get it all hooked up then thread the spring on last. what a pain in the ass. Waitin to get cylinders back so i cant fire her up and ride. wish
