Minkia38 Posted June 24, 2004 Report Posted June 24, 2004 i will be installing a +6 banshee swingarm sometime soon, and its my first swimgy mad So I was owndering what else I needed? longer chain - obviously! longer brake lines? anything else? ill be switching from stock axle / stock swingarm to a +6 honda style with LS axle Quote
Cotton eyed Joe Posted June 24, 2004 Report Posted June 24, 2004 Maybe a revalved rear shock, other than that....thats it. Quote
Chemical Castration Posted June 24, 2004 Report Posted June 24, 2004 All you need is a longer chain, extended brake cable and revalve the shock. And it should be ready to go! Quote
DUNEDEMON Posted June 24, 2004 Report Posted June 24, 2004 The re-valve on the rear shock is a great idea but you will also need a new rear spring - one with increased rate to compensate for the length of the swingarm. Quote
kenr74 Posted June 24, 2004 Report Posted June 24, 2004 Don't forget about new bearings for the pivot if they are old. It's also a good time to put a new roller on if you still use the round kind. Quote
