well i though it might be tire pressure , but that was correct. what would make my quad pull to the right when doing a wheelie. i was thing my axel not being aligned?
mine does the same thing... I cant pin point it either. I thought it might be a slight difference in my chain tensioners causing my axle to be slightly misaligned...
I hope someone knows... :cry:
First thought that comes to mind is tire pressure. Chain tensioners will make you pull some, but I don't think it would in a wheelie. Another thought would be the swingarm being cocked a tad one way, like one tire is a hair closer to the fender then the other. Maybe the swingarm bearings are going bad or something.
Just a few thoughts, probably not a good answer.
sredish provided some good points, I dunno, I know if I lean one way or another my shee will go that way in a wheely a bit...I'd definately check the tire pressure & make sure chit's lined up correctly in the ass end. ;)
