2004LEBanshee Posted April 21, 2004 Report Posted April 21, 2004 (edited) I bought this fuel filter and it has a arrow on it you can see it which end faces the tank and which end is for the carb. www.rockymountainatv.com/home.asp?sid=0004390928 Dont work it is the Visu-Filter In-Line Fuel Filter go to the catalog and click fuel filters it is the second one. Edited April 21, 2004 by 2004LEBanshee Quote
fixitrod Posted April 21, 2004 Report Posted April 21, 2004 I bought this fuel filter and it has a arrow on it you can see it which end faces the tank and which end is for the carb. www.rockymountainatv.com/home.asp?sid=0004390928 Dont work it is the Visu-Filter In-Line Fuel Filter go to the catalog and click fuel filters it is the second one. I think I understood that. The arrow represent the gas flow. It faces the carbs. Quote
2004LEBanshee Posted April 21, 2004 Author Report Posted April 21, 2004 Sorry about the jibberish. Didn't realize how bad it was untill I read it again. Thanks!!! Quote
2004LEBanshee Posted April 21, 2004 Author Report Posted April 21, 2004 Does a fuel filter restrict fuel flow? Or do anything to jetting? Quote
fixitrod Posted April 21, 2004 Report Posted April 21, 2004 I run on and never had a problem. I did take the petcock out of the tank and cut the stock ones off though. Quote
2004LEBanshee Posted April 21, 2004 Author Report Posted April 21, 2004 Stock What? Fuel filters? Should I do that? Quote
fixitrod Posted April 21, 2004 Report Posted April 21, 2004 You don't have to. I did it so I always would know if there was enough dirt to cause a clog. Up to you. Quote
