DIRTBIKEZ Posted March 25, 2004 Report Posted March 25, 2004 So I installed this kit from Vito's but seem to be having a problem with the throttle cable. In order to get the correct amount of free play at the throttle, all three adjusters are turned pretty far out. Now as this cable stretches, there isnt going to be much room left for adjustment. Is it possible I was sent the kit fo the twist throttle? How much longer would that cable be? Quote
Brian G Posted March 26, 2004 Report Posted March 26, 2004 It could be possible, do you have aftermarket handlebars? Also, check your cable routing one wrong turn and it can be way off. Quote
DIRTBIKEZ Posted March 26, 2004 Author Report Posted March 26, 2004 The handle bars are stock, I will double check the routing. Quote
