8HONDO Posted February 12, 2004 Report Posted February 12, 2004 can some one tell me where i can see pictures of a lightened flywheel on the forum and how it is done Quote
XTShee Posted February 12, 2004 Report Posted February 12, 2004 Try here my man http://www.bansheehq.com/forums/index.php?showtopic=21422 The pics may be fuct up cause image station is so crap at the moment Try copying the pic url to your taskbar and load it that way if ya wanna see it Quote
akpopeye Posted February 12, 2004 Report Posted February 12, 2004 look up posts by bdbanshee i beleive it is, his name is ron and his website has pics of the flywheels lightened, and then you can basically see what he does by comparing it to stock. Quote
8HONDO Posted February 12, 2004 Author Report Posted February 12, 2004 does anyone know the stock od. and the lightened od of the fly wheel after it is done and how much weight it took off? Quote
8HONDO Posted February 12, 2004 Author Report Posted February 12, 2004 does the flywheel get rebalanced or just indicated in so that it is running true Quote
akpopeye Posted February 12, 2004 Report Posted February 12, 2004 boonman and ron i think both take off 8 ounces when they do theres.....im pretty sure, i could be wrong lata Quote
boonman Posted February 12, 2004 Report Posted February 12, 2004 The flywheel gets chucked up in a lathe and turned down. 8 ounces of weight is removed from the the outer diameter of the wheel. 4.84" is the O.D. of the wheel after machining. Quote
BdBanshee Posted February 13, 2004 Report Posted February 13, 2004 Here is a pic: I remove 8-9 ounces from the O.D. of the flywheel. Since all stock flywheels don't weigh the same the amount varies, but the finished weight is the same. I built a fixture that the flywheel fits on, I do not clamp on the flywheel. And sometimes I also add slots to lighten it up more....... Quote
boonman Posted February 13, 2004 Report Posted February 13, 2004 I built a fixture that the flywheel fits on, I do not clamp on the flywheel. That is next on my list!! I am sick of flipping jaws around all the time!! Quote
8HONDO Posted February 13, 2004 Author Report Posted February 13, 2004 boonman, i see how ytou grab the side with the magnets on it. but what about the closed off side. does that get held through the hole Quote
