FoxBansheeRacing Posted February 3, 2004 Report Posted February 3, 2004 I am putting the shee all back together tonight and I'm not sure where all the gas lines go. Its a 2 into 1 keihin. It has 4 lines and I am guessing 2 are overflow, but where do the other two go? And what two are overflow? There are two that go out from the carb and criss-cross. I need help ASAP!!!! Thanks Quote
boonman Posted February 3, 2004 Report Posted February 3, 2004 Doesn't much matter. one is an overflow, and the rest are vents. That is the case usually. As long as you have the fuel feeding in the correct orifice.... Quote
sredish Posted February 3, 2004 Report Posted February 3, 2004 I am putting the shee all back together tonight and I'm not sure where all the gas lines go. Its a 2 into 1 keihin. It has 4 lines and I am guessing 2 are overflow, but where do the other two go? And what two are overflow? There are two that go out from the carb and criss-cross. I need help ASAP!!!! Thanks The overflow comes off of the back/bottom of the fuel bowl. The other two that are up high, ones by the choke lever and the other is directly across, are the vents. The fuel feed is bigger and is the only one that is pointed upwards a little. Its on the same side as the choke just towards the back. Its really simple. Really all 3, other than the fuel feed, go towards the back of the bike, I don't really think you can mess them up, and if you have the fuel feed wrong, you'll just dump fuel onto the floor. Scott Quote
