Hey everyone,
I was just wondering if any of you guys have any bends in your shee frame. I have two spots. 1 - is where the grab bar joins to the frame, it bent down.
2 - is the part of the frame infront of the gas tank, i rolled the shee hard one day and that whole part in front of the gas tank, alos the part where the top of the radiator connects to.
Well i was just wondering if you guys have any bends and what is the best way to fix these bends with out making the frame weak.
Thanks,
Jo
Bend the steering loop back with a come-a-long (pulley) and when it lines up correctly, put a couple of braces on it. I put a piece of angle iron on each side of mine going from frame straight up to curve in loop. On the subframe just bend it back and try not to wreck again! ha ha ha
