mr. chainsaw Posted January 2, 2004 Report Posted January 2, 2004 Hi new to the fourm. I have a 2000 Banshee. My question is the axle has to much play in the swing arm. Do I tightin it by backing the lock nut off on the left side and tightin the oter nut? Also is it reverse thread or not. Thanks ahead of time. Quote
mrmatt Posted January 2, 2004 Report Posted January 2, 2004 Does the axle move in the carrier, while the swingarm stays still? Or does the whole swingarm move back and forth? Either way you will probably need new bearings. Being a 2000, it is about time, if not overdue if you ride in muddy/wet conditions. Quote
