Asrus Posted September 2, 2020 Report Posted September 2, 2020 I have an 01 banshee that I just rebuilt, chariot cool head with 20cc domes, vforce 4 reeds, over bored to 65mm. I got it to start for .5 seconds before it died. I have the carbs jetted fat for tuning, 340 mains 30 pilots, Third clip position. The bike is getting a spark, way better compression than before (haven't done a true test yet) and the plugs are wet with fuel. Im sure in just flooding it out because of the excessive jetting but I could be wrong. I do smell fuel after a few kicks. Any info would be helpful! Quote
iTeach Posted September 3, 2020 Report Posted September 3, 2020 1. Check the spark plugs again, make sure it’s a bright blue spark. 2. Clean the carburetors. 3. Check for fluid leaks (gas, coolant etc) 4. Do a compression test just to make sure. 5. Do a leak down test as well. Are you running TORS? Quote
