Bikelife305 Posted September 30, 2019 Report Posted September 30, 2019 Here what's going on when I get on the thottle it puff a cloud of white smoke on both sides more on the leftside, motor has been sealed new main seals and no leak in cases not burning tranny oil or no coolant.smoke smell real strong like fuel..could it be that is time to rebore my cylinders? 150psi both side mods: ported 64mm cylinders, 35mm carbs, stock crank, CPI pipe, Quote
ginger Posted September 30, 2019 Report Posted September 30, 2019 what ratio are you mixing your fuel at? if it is really rich or has a lot of oil in the ratio it will make it smoke extra. remember it is supposed to smoke a little it is 2 stroke. Quote
Bikelife305 Posted September 30, 2019 Author Report Posted September 30, 2019 7 minutes ago, ginger said: what ratio are you mixing your fuel at? if it is really rich or has a lot of oil in the ratio it will make it smoke extra. remember it is supposed to smoke a little it is 2 stroke. 32:1 ratio. I know it's a 2stroke but smoking way to much then what it support too then any other banshee next to me. Quote
ginger Posted September 30, 2019 Report Posted September 30, 2019 do a plug chop, you are prolly rich on jetting. I know most guys, and myself run 40:1 Quote
