Noaly125 Posted September 1, 2019 Report Share Posted September 1, 2019 Just got a new banshee and it starts fire stick but while you're riding it when it gets warm the right cylinder will go dead and every once in awhile pick back up and run like it's supposed to the person I got it from said it could be the stator Quote Link to comment Share on other sites More sharing options...
the boris Posted September 1, 2019 Report Share Posted September 1, 2019 I don't think stator is the issue, it's a wasted spark system, which means both spark plugs fire at the same time,so you would have a problem with both cylinders.Check the cable and the spark plug boot, also swap the plugs and see if anything changes.Check the fuel supply too, maybe your carburetor float level is low thus not getting enough fuel on time. Sent from my ONEPLUS A3000 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Noaly125 Posted September 1, 2019 Author Report Share Posted September 1, 2019 I have changed plugs and swapped wires. When you first start it it runs great you will be riding and the left side will drop stop and leave it idling it may pick up and it may not. And while you're riding it it may also pick up. Both cylinders have around a hundred and thirty-five lb of compression 1 Quote Link to comment Share on other sites More sharing options...
the boris Posted September 1, 2019 Report Share Posted September 1, 2019 Compression is very good.What about fuel?When that side stops working did you try to pull the spark plug out to see if its wet? Sent from my ONEPLUS A3000 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Noaly125 Posted September 1, 2019 Author Report Share Posted September 1, 2019 Yes both spark plugs was wet just traded carbsand it swapped to other side 1 Quote Link to comment Share on other sites More sharing options...
the boris Posted September 10, 2019 Report Share Posted September 10, 2019 Yes both spark plugs was wet just traded carbsand it swapped to other sideDid you figure out what was wrong? Sent from my ONEPLUS A3000 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Noaly125 Posted September 11, 2019 Author Report Share Posted September 11, 2019 The float was set way too low but the carburetor was also junk ordered two new carburetors and now have no bottom in I have to feather it through to get the quarter half throttle and then it comes alive 1 Quote Link to comment Share on other sites More sharing options...
