joshpam8 Posted May 24, 2018 Author Report Posted May 24, 2018 what its doing? lean on that side? Yea it leans out just into the throttle and takes a few seconds to idle down only that carb though my quad has the 403 eliminator kit with shearer pipes 5mm billet crank v force 4 reeds dual 35mm carbs bored to 36.3 k&n filters 165 main 55 pilot air screw 3/4 turn out Sent from my SM-G930V using Tapatalk Quote
Ayesully810 Posted May 24, 2018 Report Posted May 24, 2018 i would stay after duncan if i were you Quote
joshpam8 Posted May 24, 2018 Author Report Posted May 24, 2018 i would stay after duncan if i were youYea I will I just ordered new 35mm today if it fixes the problem I'll be calling him back he told me to put a richer needle in it Sent from my SM-G930V using Tapatalk Quote
Ayesully810 Posted May 24, 2018 Report Posted May 24, 2018 3 minutes ago, joshpam8 said: Yea I will I just ordered new 35mm today if it fixes the problem I'll be calling him back he told me to put a richer needle in it Sent from my SM-G930V using Tapatalk what needle are you running now? Quote
joshpam8 Posted May 24, 2018 Author Report Posted May 24, 2018 what needle are you running now?Duncan sent it with a cgk Sent from my SM-G930V using Tapatalk Quote
Ayesully810 Posted May 24, 2018 Report Posted May 24, 2018 4 minutes ago, joshpam8 said: Duncan sent it with a cgk Sent from my SM-G930V using Tapatalk put a cel in 5th groove if it still lean you know for sure lol Quote
joshpam8 Posted May 24, 2018 Author Report Posted May 24, 2018 put a cel in 5th groove if it still lean you know for sure lolYea might have to lolSent from my SM-G930V using Tapatalk Quote
